Good morning
The main program has been uninstalled but there are several odd entries left in the registry which I cannot delete. The following details are:-
Registry directory entry is Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\bam\State\UserSettings\S-1-5-21-3555011155-1756623252-4010866811-1001
Within this are several entries
\Device\HarddiskVolume11\Program Files\FxSound LLC\FxSound\Apps\DfxSetupDrv.exe
\Device\HarddiskVolume11\Program Files\FxSound LLC\FxSound\FxSound.exe
\Device\HarddiskVolume11\ProgramData\FxSound LLC\FxSound\updates\Update\fxsound_setup.exe
\Device\HarddiskVolume11\Users\Kevin Evans\Downloads\FxSound Installer.exe
\Device\HarddiskVolume11\Users\Kevin Evans\Downloads\fxsound_setup (1).exe
\Device\HarddiskVolume11\Users\Kevin Evans\Downloads\fxsound_setup.exe
\Device\HarddiskVolume11\Users\Kevin Evans\Downloads\fxsound_setup-1.1.14.0.exe
\Device\HarddiskVolume13\Downloads\fxsound_13.028_setup.exe
\Device\HarddiskVolume13\Downloads\fxsound_setup.exe
Next registry directory is
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\bam\State\UserSettings\S-1-5-21-3555011155-1756623252-4010866811-1001
Entries in this are
None of these can be deleted in the normal manner.
Is there a work around?
Thank you so much for your help.
Regards
Kevin
