No, these entries will be deleted by Windows automatically.
Question is, are those entries I listed preventing FXsound installation?
These registry entries do not affect the FxSound installation.
Can you please share the screenshot of the installation error.
Do you have fresh files msi*.log or msi*.log.txt in %localappdata%\temp%
lots of msi*.log in temp folder.
Archive the last 5-10 files and share them via file sharing or cloud service.
Hope you can decipher these
Kevin
(Attachment Doc1.docx is missing)
Looks like the file didn’t get through. Can I send via wetransfer process?
Away from my pc now. Send the file tomorrow.
File sent
Any news with this?
Did you send this to @raddy ?
The files went to u3ulis+5713u7tgj0b6w@sharklasers.com
Hope that helps
Is there any resolution to my issue?
As I haven’t had any recent responses, can I take it that there is no solution to my problem. Still unable to install the program as it states a previous version is still present. Nothing left on my PC relates to any previous version of FX Sound!
Online tech support does not work telepathically, so-to-speak. We cannot look into your machine to locate the exact cause of this particular issue on your behalf.
You can find a summary of alternative audio enhancers at the end of the standard troubleshooting list.
Appreciate that of course, but did the file I sent you give you any clues? Like FX Sound and its a shame I’m unable to use it any more. Thanks for your help.
Honestly not sure if anyone was able to take a look at it just yet. And I’m unfortunately not sure how to make sense of the files.
