its okay if you dont understand…last explanation here 1 input audio sources pc..split 2 output devices at same time(play at the same time)..if you still dont understand its ok…
Let me see if I understand: what you’re asking for is the ability to reproduce an audio source through two different outputs, say the 3.5mm audio jack and the TV speakers through HDMI?
In summary, to play the same source through 2 or more outputs at the same time!
Is that what you are refering to?
Yes correct
OK, now I understand. The problem is not:
- To MIX two input signals
- But to DUPLICATE the Window audio output to 2 different outputs.
This cannot be done from FxSound that works before the Windows mixer, but must be done after the Windows mixer, either from Windows itself or from mixer-type programs you install.
Both solutions are explained in the attached link.
It’s ok I’m just asking if this can be done from FX sound..I have another PC can do that thing thru stereomix adapter from windows it self…thanks btw
Why you can not change to 9 or 15 bands?
Opening the “Settings” with the gear icon and then in the “Settings window” pressing another time the gear icon you should open the “General preferences” tab
And then using the top right control called “Num bands” you can change the number of bands to 31, 20, 15, 10 or 5 bands.
The 10 bands is very similar to the old 9 bands, but with some advantages, and can load the old 9 bands presets.
i meant i cant go back to 9 or 15 becouse i already use 31 so much,i never go back to 9 or 15 band ,yes i can go change to use 9 or 15 but i dont want …31 so much precise control in my ear…
i dont know others but 31 make so much simple to adjust what i want..tq so much for bring 31 band…i hope official fxsound release this version as well….thanks so much from my heart
OK, now I understand, and I am happy for your words.
(sorry for my bad and a little strange english)
@m3n3v3r I am integrating the changes from @Theremino to our code in GitHub. You can expect the official version with the equalizer changes in a couple of days.
yeay this is dope super excited…
any ETa? thanks @bvijay
ETA : Acronym for “Euskadi Ta Askatasuna” (a Basque separatist organization).
Estimated Time of Arrival
FYI, I was just kidding, of course. BTW, no worries. I get it, I’m kind of a noob when it comes to English acronyms myself, IDK but I’m trying to learn. POV maybe I can learn so I can reduce the wear on the keys. ![]()
I have integrated the features. I have to complete the translations for the new text added. I have taken the audio features from Theremino code, and made UI changes in FxSound without making any drastic changes in the look and feel.
After completing the translation I should be able to make the release next week by Tuesday.
Oh, that’s really great! I can’t wait for it… I’m really happy to hear that.![]()
I have built and released the beta version 1.2.0.0 with the new audio features implemented by Theremino. Please download and give it a try.
@Theremino The integrated code is in dev branch. I have taken all your audio implementation but not done any major changes to FxSound UI and kept the UI theme as it is. I have modified the audio settings UI with sliders.
We can discuss and merge your other UI code changes based on user requests and bug reports.
It would be a great help if you can review the code changes in dev branch give your feedback in GitHub.
wow so exciting news….downloading now
