Self-explanatory! We have a parametric EQ function built-in that allows you to adjust the center frequency of the bands we have available, but some of you guys have requested more anyway.
Why not make it ISO standard?
A 10-band EQ uses bands (frequencies) an octave apart.
32-64-125-250-500-1k-2k-4k-8k-16k
Another popular setup is the Serge RESEQ:
29-61-115-218-411-777-1.5k-2.8k-5.2k-11k
I would prefer this to the limited Parametric settings. Or give us more control over the Parametric settings.
It would be nice to have a ācompleteā EQ that reaches from 20Hz all the way to 20kHz⦠![]()
Iām using FXsound because Equalizer APO fails to configure my hdmi audio via my AMD graphics card and it doesnāt want to start with Windows to well either. EQ APO is a very powerful program but most people donāt really need all of its functions itād be nice to see FXsound offer something similar but with your better GUI. Maybe a Pro or Advanced option that has a 10 or 15 band EQ, custom frequency points and adjustable Q. I like to use DSP to correct the frequency response of my headphones or speakers Iām using via a calibrated mic and REW. Right now EQ APO is really the only option out there that most people like me use but it doesnāt run the smoothest and looks like Windows XP. ![]()
Hi!
Today I found FXSound and itās ⦠nice. But please ⦠add more lower bands!!! Please! ;o)
EQ APO would be a great alternative - if it would be working proberly, but it doesnāt. So let me hope for FXSound. Maybe one more lower cf-band? FXSound is lacking sub bass!
Keep up the good work guys!
Hi you all. Iām also using FxSound because I discovered it as an alternative to EQ APO (which doesnāt work on my new computer).
I would like to be able to correct audio output as much as possible for every output device. Iām nou using any Fx because I relay on public and free correction curves for every headphone. The point is that 9 bands is no enough. I think that having 12 would be great, to be able to isolate at least a couple of frequency ranges and correct it.
There are more sofisticated features like having the possibility to adjunt all the range just entering the standard bands and gains like APO like a list of numbers in raw text format, but I understand that this is maybe too technical for the scope of this tool.
Having 15 bands would also be wonderful, but maybe not everybody is looking for so many bands. Probably it could be a good idea if we could select how many bands we want on settings.
In any case, thanks for this useful tool for audiophiles !!
Another user requesting the addition of lower frequency bands:
This would require us to dissect some very old code, but we will give it a try soon and see if this is doable!
Any news on that? Will we get some more (lower) EQs next time?
would be great!
Donāt go jumping the gun; I think itāll take a little longer than five days to figure this outā¦
Okay okay ⦠Iām patient. ![]()
Another similar request, posted today:
And, one more, posted today:
Adding one more user to the list.
And one more, the difference here being a request for higher frequencies:
Hi, we made all the requested changes:
The license is unchanged (GPL v3), enjoy using our code as you prefer.
Greetings to all from T-System
@Theremino I“m gonna give it a try and come back with my feedback.
Your work is based on the 1.1.31.0 version.
The 1.1.33.0, have fixes that for me are crucial.
@Theremino
Whenever I click the OFF button in the app, it shows this continuous error, and it repeats several times. I have to click āAcceptā about 20 times to get rid of it. This only happens when Iām playing a video or music in the background.
Dear Shepard-N7
The error message you experienced (and some other improvements) should be corrected in the version 2.0.1 published here: Audio | theremino
And now we are working to improve the installer changing it from a BAT to a true EXE installer.
It would be really great if some of you would integrate our improvements into the main thread. Then we could just put a link on our site and dedicate our time to other things (we have more than 150 Open Source applications to maintain on our siteā¦)
We tried to figure out how to use GitHub to integrate our changes but itās too complex for our neurons, our skills and our time.
Hello everyone from T-System
