Q Factor and Adjustable EQ Bands
Hey,
I’m looking to switch from Equalizer APO to FxSound and the biggest thing holding me back is that the EQ is very limited
I’m using https://autoeq.app to get the correct my frequency response of my headphones, and I want to use that in your app
I’ve seen people discuss about this before, I really think this should be implemented
Thanks!
The Q value is 1.52743447, and the Bass Boost Effect works at 62,5 Hz (which I discovered by opening a Preset .fac file in WordPad).
For the feature request to add more EQ bands, see:
For the feature request about AutoEq Presets, see:
