Is it possible to set Q-Factor?
Hello, I am new EQ software and I wonder if there is a setting or settings in FxSound equivalent to the Q-Factor. Is there a way to achieve the same result? Thank you in advance for your response.
Hi Ludwvin,
Sorry to disappoint, there are no Q controls or any controls related to the Q factor in FxSound, only frequency controls below each band.
What is known, is that the Q value is 1.52743447 , and that the Bass Boost Effect works at 62,5 Hz (which I discovered by opening a Preset .fac file in WordPad).
If you’re looking for pinpoint precision, EqualizerApo is probably the most advanced free equalizer tool out there, supporting infinite bands and unlimited customization options, and should be compatible with FxSound on a capable system.
Thank you @doolhoofd, there is no worry. I was just wondering if there was a way. I am no expert, and I am enjoying the different presets of FxSound. I plan to start playing around a bit with the settings.
