Customize EQ
Sorry if this has been discussed already.
I am using FX sound since a while and really appreciate its functionality. However, I do have a request …
It would be fantastic to move the values of the existing knobs to something more reasonable. IMHO, given the 9 knobs currently implemented, spreads like 32, 64, 125, 250, 500, 1k, 2k, 6k, 12/16k or 50, 100, 250, 500, 1k, 2k, 4k, 8k, 16k make much more sense. 10 knobs would even allow for a nice octave-based spread, e.g., 32, 64, 125, 250, 500, 1k, 2k, 4k, 8k, 16k.
Even more so, having the values fully adjustable would be a dream, but I understand that this likely involves much more coding than adjusting the fixes values.
Also, a Low Cut (and if possible also a High Cut) filter would be beneficial, especially in situations where you need to remove unwanted low-end rumble (or reduce harsh high frequencies). In my particular case, since I use a 2.1 setup, the 86Hz setting is mostly useless as it is not particularly affecting the sub bass.
It would be amazing to see these improvements in future updates. Any plans?
Thanks for the feedback! Something like this is definitely on our todo list.
