Sure thing.
I’ll be at home and at my desk in about two hours to test.
@james this is a tradeoff due to the hotkey customization. Since only one hotkey editing can be accommodated in the new UI control that we have added, navigation with next and previous hotkeys for preset and device selection is now combined to only next.
Yep. Toggle only goes one way, downward through the list.
Seems like a perfectly reasonable solution.
Someone is asking about the same keys here
Hello,
Just tested 1.20 version.
Working fine with french keyboard (AZERTY).
What I found :
When using keyboard shortcuts, for example CTRL + ALT + Q, Windows notifications take a bit of time before being displayed.
A proposal for CTRL+ALT+A : give numbers to differents ambients then direct jump to movies would be 2, direct jump to music would be 5,…
Forgot to say that Windows notifications are not mandatory.
Then, a settings checkbox to remove/hide notif could be useful…
Ah gotcha. Okay as a nice-to-have-feature later we can change the UX for selecting hotkeys to offer the ability to cycle to previous preset and device.
You can add them into the settings, you know right? Make it optional. Jesus christ.
