Suggestion for the choose preset menu, and for importing presets!
As I reported, one problem was solved a while ago, I will give two suggestions!
I say because I want the best of your program!
When I go to import the presets, the program is kind of dumb and unable to let me choose any folder of the operating system anywhere that I unzipped and recognize that the presets are there inside the folder that I chose, I am forced to unzip and throw the presets directly into the root of this c: or directly into the Windows songs folder, when I do this it recognizes that the presets are there !
The other serious thing in the menu that defines the presets that I want to leave as a standard type as an example preset transcriptio n!
I wanted it to be something standard like I click on the arrow the presets menu appears and does not disappear [closes], so I choose the preset using the mouse scroll, I click on the preset I want and the menu closes, I never liked the way this menu chooses the prese ts!
Don’t take me the wrong way, I just want your software to be better and better than it already is!
Thank you very much for your atten tion!
Hi @RonaldoPDN
Thanks for your suggestions to improve FxSound user experience.
To import presets, you can choose any folder which has .fac files. It need not be just C: or Windows Music folder. In the Import Presets dialog, you can navigate to any folder through the dropdown and folder list. Or you can directly type the folder name in the textbox.
We will still look at ways to improve the preset import experience.
Can you please elaborate on your second suggestion on preset menu?
