Hi all, I am new to FxSound and I have downloaded the extra presets, but on my menu it is greyed out where to import them, do I have to pay for this to import other presets?
Can someone please help me out??
Thanks
David
Thanks
David
No need to pay for anything. Did you follow the instructions here? Importing and Exporting Presets in FxSound - FxSound Learning Center
Thanks for the guidance, however, when i look atbthe menu, both export and import ate greyed out?
Oh weird! Can you uninstall and reinstall to make sure you’ve got the latest version? Download FxSound - Boost Your Sound On Windows
Hi @david1968,
Import Presets menu option can be disabled if there is any change done in the current preset EQ settings to avoid losing the changes on import. It is also disabled when FxSound processing is turned off through the power button.
If the current preset is modified, there will be a * in the preset name, indicating the change. You can undo the change by selecting another preset and ignore the changes.
