Every time I download presets and go to import, I get message “Presets not found in this file”.
Could you try moving the imported presets to another location? Importing and Exporting Presets in FxSound - FxSound Learning Center
I get the same message no matter where I put them
Hi @Moto1
The bonus presets will be downloaded as a BonusPresets.zip file. You need to extract the zip file and then select the extracted folder to import the presets. Can you try this?
I have tried ALL the methods shown here and I can’t install the preset(12 + 59). The zipped folder won’t extract, no matter which Zip extractor software I use!! Can someone create an executable file with the presets? I found one but it doesn’t extract.
Are you downloading the bonus presets from https://github.com/fxsound2/fxsound-app/raw/main/bin/BonusPresets/BonusPresets.zip?
Yes, but it will not extract and, how I can integrate those presets into my FX application?
The zip file is standard zip format. You can extract it on Windows and then import the presets by selecting the extracted folder.
I used 7-zip to extract the files, and they extracted. I should clarify my problem: How do I get (import) the presets into the FX app? I thank you for your response and your help, Sir!
Select the Import Presets menu option in FxSound,
In the dialog that pops up, select the folder where the preset files are extracted using 7-zip
Option is grayed out, can’t select. This is designed for computers ENGINEERS, not for regular people like me. Something that install’s itself is a better way to get the presets!
I gave up on the presets! Thank you for your help with this!
