How far will FXSound boost sound quality?
I wanna know far FXSound will take the quality too, macbook level? maybe below? Also is it better than the dts ultimate that comes with my laptop?
I would say, it depends on how you define “quality” and “better.”
Anyway, those are questions which I already more-or-less answered in these posts:
Thank you
FXSound can noticeably improve sound quality, especially on basic speakers or headphones. But if you want more control and deeper audio customization, Equalizer APO is the better choice. It takes a bit more setup, but the results can be much more precise.
