can anyone help my fxsound is going through a DAC and the volume keeps resetting to 100 ?
Is the volume getting reset every time you connect the DAC?
yes every time i boot the pc and turn on the DAC
This happens because FxSound resets volume when a new audio device (DAC) is detected at boot.
To fix it, set your DAC as the default device before starting FxSound, then adjust the volume and save a preset. This will make FxSound remember the level instead of resetting to 100 on each boot.
where should i set DAC to default as when i try to do this in windows it just jumps back to fxsound Immediately ?
