VB cable changes
is it possible to make it so FX sound doesnt try to connect to a VB cable Input
and have a toggle for it in case people want to use it
in my case though, I use VB input for recording and when my headphones disconnect, it plays my desktop audio through my Cable and usually ends up blasting into the call Im in.
We don’t have a way to disable an input within the FxSound software. You could try setting a different preferred output device so that FxSound will switch to that one instead of the VB cable.
