I noticed that FxSound did not get updated on Windows 11.
The Last Run Result for the FxSound/Update Task in Task Scheduler shows:
The system cannot find the file specified. (0x80070002).
That is because the Task configuration is wrong:
<Actions Context="Author">
<Exec>
<Command>C:\Program</Command>
<Arguments>Files\FxSound LLC\FxSound\updater.exe /silent</Arguments>
</Exec>
</Actions>
(In %windir%\System32\Tasks\FxSound\Update)
Obviously that should be:
<Exec>
<Command>"C:\Program Files\FxSound LLC\FxSound\updater.exe"</Command>
<Arguments>/silent</Arguments>
</Exec>
</Actions>
I don’t know how your installer creates the Task but the double quotes ( " ) are required to make sure it is configured correctly.
HTH,
flip
