The path 'C:\Users\SVIPAppData\Roaming\FxSoundLLC\FxSound 1.1.17.0\installfxsound.x64.msi cannot be found.Verify that you have access to this location and try again,or try to find the installation package
'fxsound.x64.msi in a folder from which you can install the product FxSound.
The computer already has version 1.1.17 installed. Previously, it was possible to update and install directly without uninstalling, which is a habit.
I have also encountered installing update 1.1.17, but I can directly find the “installer” folder in the following path or create a new one. Please ensure that there are no files before installation (if any, delete and empty them) “C: Windows Installer”
After processing, the update can be installed normally.
The system is WIN10, 21H2-19044.1889
However, after downloading on 1.1.18, the update cannot be installed using the 17 method, which Uncomfortable
Fortunately, after giving it a try and uninstalling the original version 1.1.17 completely, you can install it directly.
电脑上已装有1.1.17版本,以前是能直接没卸载就直接更新安装的,这习惯。
安装更新1.1.17时也遇到过,但直接在下面的路径中,找到“installer”文件夹或新建,要保证在安装前没有任何文件(有则删除清空) “C:\Windows\Installer”
处理后,直接能正常安装更新。
系统是WIN10,21H2-19044.1889
但,在1.1.18下载后,却无法用17的方法来安装更新,这…难受
还好,试了下,将原1.1.17版本完全卸载后,就可以直接安装了。
