FxSound does not update
I installed the app yesterday and today I wanted to check if there was any update just so I can always keep it updated. The updater says yes, there is an update, then… why everytime I try to install, it says this:
Please help, this is a great app.
My specs:
Windows 11 Pro Education Ver. 23H2
11th Gen Intel(R) Core™ i3-1115G4 @ 3.00GHz
4GB RAM
Intel(R) UHD Graphics
Hi, welcome to the forum.
Which version of FxSound do you currently have installed?
Where did you download it from?
And does it still work?
The latest version released is 1.1.22.0, there are no official updates available after this version yet.
You can find your current version number in the Help tab of the Settings menu.
If you have a previous version, then just go to fxsound.com, download v1.1.22.0 and run the installer. This should update you to the latest version.
And if FxSound no longer works, then follow the instructions under bullet point 21 of the main troubleshooting list at the top to manually remove the FxSound Audio Enhancer driver from Device Manager; run the installer .exe for v1.1.22.0 afterwards; and post back to let me know if this solved your problem (or not).
Yes, it worked. Apparently, Microsoft Store only has support until 1.1.16.0 and I had that version. The app worked perfectly just the updater was useless, now I have the version 1.1.22.0 from the original site you shared. Thank you.
Happy I could help. :+1:
