UI Bug v 1.2.8.0 beta
Greetings @bvijay
I’m currently using version 1.2.8.0 beta of FxSound and I’ve noticed a small bug. It doesn’t affect audio quality, but it does impact the user interface functionality.
You see, when you enable the “Always On Top” option and then try to export or import Presets, the preset selection window ends up behind the main application window, making it impossible to make any selection. This forces you to press “ESC” to unfreeze the application and then uncheck the “Always On Top” option in order to export or import presets.
It may not be a major bug, but I’m reporting it to help make FxSound even better.
Keep up the good work.
Thank you @Shepard-N7 for reporting this UI bug. I have fixed it in the code and the fix will be available in the next release.
