FxSound Always On Top After Update
After the update the FxSound control window stays always on top of all other aplications. I cannot find a way to change this option. Is this an option available with donation?
We implemented always on top for mini mode as per a user request. Feature Request, systray output toggle - General Discussion - FxSound
The expanded view of FxSound is not always on top.
Yeah, I like editing posts 5,000 times. Sorry.
I use a utility called WindowManager to handle these things (i.e. essentially “undo” the always-on-top behavior).
You can also use something like NirCmd to run: “nircmd.exe win settopmost process FxSound.exe 0” and achieve the same effect.
So, you can either use a kludge like that, or use expanded mode, because one FxSound user has a trackball.
Anyway you can just make this an easy option to set on or off.
Like the user above me says, would it be possible to add an option to change this… maybe on or off.
I love having FxSound minimized on my other screen but very annoying when I move another window like a video over on the other screen but FxSound stays on top of it.
Thanks for this fantastic tool, made my audio soooo much better! <3
Yes, we can consider providing an option to disable always on top.
I have implemented the menu option to enable/disable always on top. The feature will be available soon in the next release.
Menu option to disable always on top is now available in the beta release v1.2.4.0
