Maybe you guys like seeing FxSound doing it’s magic and would like an option to keep it on top.
You can use “always on top” kind of app or multi tools like “MenuTools” or “PowerToys”. I don’t think the always on top is necessarily tho
By the way I found one random issue with FxSound that is, when i click the icon in the systray, sometimes its window appears in the background (behind of currently opened window). I can see it appears in the taskbar and need to click on that to bring it to the foreground.
That’s odd. Let me know if you get a sense of when this happens and doesn’t. It will be hard for us to test this otherwise.
I notice one thing, that is, 1st click on the tray icon its window appears in front. 2nd click it closes. Click again and it appears behind other window(s). It stays behind for subsequent clicks.
Well if I click the X to close its window, then the next click on the tray icon will open it correctly in front. Oh means I should not close it by clicking tray icon.
Not sure it behaves the same on other’s system. It’s ok though. Small issue. ![]()
Ok thanks let me test this and get back to you.
Okay I was able to replicate this. @bvijay does this seem like an easy fix we can plan to add to the next release?
Yes, this could be an easy to fix issue. I will add the fix in the next release.
