Translation: Simplified Chinese
Causes
In the previous version I raised the need for multi-language support and helped to improve the Simplified Chinese translation. Today I saw on the forum that there is a test version supporting multi-language interface(Translation before feeling involved), but I found that the translation is not very good, so I posted to improve the translation.
Translation
Update date: February 20, 2022
English 简体中文
JCTRIDX0.
Oops! There’s an issue with your playback device settings. 哎呀! 你的播放设备设置有问题。
Before we can get started, please go through the 在我们开始工作之前,请先浏览一下
JCTRIDX1.
troubleshooting steps here. 此处为故障排除步骤。
JCTRIDX2.
if you’re still having problems. 如果你还有问题。
JCTRIDX3.
Contact us 联系我们
JCTRIDX4.
Error in system audio configuration. Unable to run FxSound 系统音频配置出错。无法运行FxSound
JCTRIDX5.
OK
JCTRIDX6.
Click here to see what’s new on this version! 单击此处查看此版本的更新新内容!
JCTRIDX7.
FxSound in system tray FxSound在系统托盘中
Click FxSound icon to reopen 点击FxSound图标,重新开启
JCTRIDX8.
Thanks for using FxSound! Would you be interested in helping us by taking a quick 4 minute survey so we can make FxSound better? 谢谢您使用FxSound! 您是否有兴趣帮助我们,做一个4分钟的快速调查,以便我们能使FxSound变得更好?
JCTRIDX9.
Take the survey. 参与调查。
JCTRIDX10.
Changes to your preset are not saved. 对预设的改变不会被保存。
Do you want to exit? 你要退出吗?
JCTRIDX11.
Do you want to ignore the changes? 你想忽略这些变化吗?
JCTRIDX12.
Output Disconnected 输出端断开连接
JCTRIDX13.
Output: 输出
JCTRIDX14.
Changes to preset %S are saved. 对预设%S的更改已被保存。
JCTRIDX15.
New preset %S is saved. 新的预设%S已经保存。
JCTRIDX16.
Reached the limit on new presets. 已达到新预设的限制。
JCTRIDX17.
Preset %S is deleted. 预设%S被删除。
JCTRIDX18.
Presets are restored to factory defaults 预设会恢复为出厂默认值
JCTRIDX19.
Preset file %S already exists in the export path, do you want to overwrite the preset file? 预设文件%S已存在于导出路径中,是否要覆盖预设文件?
JCTRIDX20.
FxSound is %S. FxSound是%S。
JCTRIDX21.
on 打开
JCTRIDX22.
off 关闭
JCTRIDX23.
Preset: %S 预设:%S
JCTRIDX24.
Clarity 清晰度
JCTRIDX25.
Ambience 堂音
JCTRIDX26.
Surround Sound 环绕立体声
JCTRIDX27.
Dynamic Boost 动态增强
JCTRIDX28.
Bass Boost 低音增强
JCTRIDX29.
Enhances and elevates high end 增强和提升high end(终极高保真)级别
fidelity and presence 保真和临场效果
JCTRIDX30.
Thickens and smooths audio with controlled reverberation 通过控制混响来调节音频的厚度和柔和度
JCTRIDX31.
Widens the left-right balance for expansive, wide sound 拓宽了左右的平衡,使声音更加宽广。
JCTRIDX32.
Increases overall volume and balance with responsive processing 通过共鸣处理提高整体音量和平衡性
JCTRIDX33.
Boosts low end for full,impactful response 提升了低频,使之具有完整的、有冲击力的响应。
JCTRIDX34.
Super-low Bass. Increase this for more rumble and thump, decrease if there’s too much boominess. 超低频。增加它可以获得更多的隆隆声和 砰砰声,如果有太多的轰鸣声就减少。
JCTRIDX35.
Center of your Bass sound. Increase this for a fuller low end, decrease if the bass sounds overwhelming. 低音中心。增加这个数值可以获得更丰满的低频,如果低音听起来太过沉重,就减少这个数值。
JCTRIDX36.
The low end of your mid-range. Increase this to make vocals sound rich and warm, decrease it to help control instruments that sound loud and muffled. 中频的低音。增加它可以使人声听起来丰富而温暖,减少它可以帮助控制那些听起来很响很闷的乐器。
JCTRIDX37.
A focal point of the low-mid-range. Increase this to bring out electric guitars and vocal volume, decrease it to reduce any boxy tones. 中低音域的一个关键点。增加它以突出电吉他和人声的音量,减少它以减少任何 箱体 的音调。
JCTRIDX38.
The center mid-range band. Increase this to drastically boost rhythm instruments and snare hits, reduce it to cut out nasal tones. 中心的中频段。增加这个频段可以大幅提高节奏乐器和小鼓的音质,减少这个频段可以消除 鼻音。
JCTRIDX39.
The high-mid-range. Increase this to get more instrumental harmonics, reduce it to improve drums that have too much clickiness or orchestral instruments that are piercing. 中高音域。增加它可以得到更多的乐器谐音,减少它可以改善有太多 咔嚓声 的鼓声或刺耳的管弦乐器声。
JCTRIDX40.
The lower end of the high-end range. Increase this for more vocal clarity and articulation, reduce it and move the frequency wheel up and down to find and cut out overly loud S and T sounds. 远端中高档-关闭音域。增加这个频率可以更加清晰的发声和发音,减少这个频率,并上下移动频率轮,以找到并切掉过大的“S”和“T”音。
JCTRIDX41.
The core high-end range. Increase this to make your audio sound more like it’s in an airy, large space, reduce it to help with room noises and unwanted echoing. 核心中高档-关闭音域。增加它可以使你的音频听起来更像在一个通风的大空间里,减少它可以帮助解决房间噪音和不必要的回声。
JCTRIDX42.
The highest range of average human hearing. Increase this to give your sound more of a crisp tone, with lots of overtones. Reduce it to remove hiss or painfully high sounds. 人类平均听力的最高范围。增加它可以使你的声音更加清脆,有很多杂音。减少它可以消除嘶嘶声或痛苦的高声。
JCTRIDX43.
This wheel allows you to adjust which frequencies this EQ band is affecting up or down to target different frequencies/pitches. The EQ slider above controls the volume of this EQ band. Increase or decrease to boost or cut a portion of your audio’s frequencies, without modifying the rest of your sound. 此滚轮可让您调整此均衡器频段向上或向下影响的频率,以达到不同的频率/音高。上面的均衡器滑块控制该均衡器频段的音量。增加或减少以提高或降低音频的一部分频率,而不修改声音的其余部分。
JCTRIDX44.
SUBSCRIBE NOW 立即订阅
JCTRIDX45.
Yes 是
JCTRIDX46.
No 否
JCTRIDX47.
Export Presets 导出预设
JCTRIDX48.
Export 导出
JCTRIDX49.
Select the presets to export… 选择要导出的预设…
JCTRIDX50.
Presets are exported successfully! 预设成功导出!
JCTRIDX51.
Presets successfully imported 成功导入预设
JCTRIDX52.
Duplicate presets not imported 没有导入重复的预设
JCTRIDX53.
Import Presets 导入预设
JCTRIDX54.
Import 导入
JCTRIDX55.
Select the folder which contains the presets… 选择包含预设的文件夹…
JCTRIDX56.
Folder: 文件夹:
JCTRIDX57.
Preset files not found in the selected folder. 在所选文件夹中找不到预设文件。
JCTRIDX58.
Settings 设置
JCTRIDX59.
Donate 捐赠
JCTRIDX60.
General 通用
JCTRIDX61.
Help 帮助
JCTRIDX62.
General Preferences 通用设置
JCTRIDX63.
Launch on system startup 在系统启动时启动
JCTRIDX64.
Automatically switch to newly connected output device 自动切换到新连接的输出设备
JCTRIDX65.
Hide help tips for audio controls 隐藏音频控件的帮助提示
JCTRIDX66.
Disable keyboard shortcuts 禁用键盘快捷键
JCTRIDX67.
Reset presets to factory defaults 将预设重置为出厂默认值
JCTRIDX68.
Turn FxSound On/Off (Ctrl + Alt + Q) 开启/关闭FxSound(Ctrl + Alt + Q)
JCTRIDX69.
Open/Close FxSound (Ctrl + Alt + E) 打开/退出FxSound(Ctrl + Alt + E)
JCTRIDX70.
Change Preset (Ctrl + Alt + A / D) 更改预设(Ctrl + Alt + A / D)
JCTRIDX71.
Change Playback Device (Ctrl + Alt + W / S) 更改播放设备(Ctrl + Alt + W / S)
JCTRIDX72.
Language 语言
JCTRIDX73.
Disable debug logging 禁用调试记录
JCTRIDX74.
Version 版本说明
JCTRIDX75.
Support 技术支持
JCTRIDX76.
Maintenance 维护版本
JCTRIDX77.
Changelog 更新日志
JCTRIDX78.
Quick tour 快速游览
JCTRIDX79.
Submit debug logs 提交调试日志
JCTRIDX80.
Help center 帮助中心
JCTRIDX81.
Feedback 反馈
JCTRIDX82.
Check for updates 检查更新
JCTRIDX83.
Open 打开
JCTRIDX84.
Exit 退出
JCTRIDX85.
Turn Off 关闭
JCTRIDX86.
Turn On 开启
JCTRIDX87.
Preset Select 预设选择
JCTRIDX88.
Playback Device Select 播放设备选择
JCTRIDX89.
Enter your preset name 输入预设名称
JCTRIDX90.
Enter new preset name 输入新的预设名称
JCTRIDX91.
Overwrite Existing Preset 覆盖现有的预设
JCTRIDX92.
Save New Preset 保存新的预设
JCTRIDX93.
Undo Preset Changes 取消预设的更改
JCTRIDX94.
Rename Preset 重命名预设
JCTRIDX95.
Delete Preset 删除预设
JCTRIDX96.
Download Bonus Presets 下载额外的预设
JCTRIDX97.
FxSound is unable to play processed audio through the selected output device. FxSound无法通过选定的输出设备播放经过处理的音频。
Another application could be using it in exclusive mode or the device could be disconnected. To disable exclusive mode follow these 另一个应用程序可能在独占模式下使用它,或者设备可能被断开连接。要禁用独占模式,请遵循以下步骤
JCTRIDX98.
steps. 步骤
JCTRIDX99.
Click here to save new presets, overwrite old ones, or reset your settings. 点击这里保存新的预设,覆盖旧的预设,或重置你的设置。
JCTRIDX100.
Settings file not found! 未找到设置文件!
Thanks a bunch!! :+1:
Hi @fairycn
Thanks for your support. Sorry I missed the content here.
The Simplified Chinese translation in the release is taken from GitHub - wcxu21/FxSound-Simplified-Chinese-Language: FxSound Simplified Chinese Language from the other message thread,.
Are there any specific text that should be taken from here and corrected in our release?
