fxsound stops for 1 second during operation and then you need to manually click on the music track or video again to make it come to life. What could be the problem?
fxsound останавливается на 1 секунду во время работы и потом требуется вручную снова нажать на музыкальную дорожку или видео, чтобы оно ожило. В чём может быть проблема?
Hi Deimos,
Which version of FxSound are you running?
Does this happen with all audio devices, or only with one specific device?
The soft reset outlined in bullet point 8 of the troubleshooting list (bannered to the top of the forum) seems like a risk-free first step to try. @raddy’s question is also a good one, and many of the other points mentioned in the list, are probably worth checking too.
Please post back to let us know your results.
