I am using DFX version 1.1.27.0. Recently I came across sound fluctuation issue. I have tried contact Microsoft Chat and they uninstall and reinstall the drivers on Device Manager. After few hours the problem started again. Then I tried contacting Microsoft Chat again, and they did the same actions as the previous chat. It works for 10 minutes then the sound fluctuations started again.
Today, I followed the same steps as the Microsoft agents. I uninstalled the DFX program and restarted my PC. The sound fluctuations were gone. Then, I reinstalled DFX, and immediately the issue started.
What I meant by sound fluctuations? Whenever a program is started, the volume will raise up little bit until the program is fully loaded. After that the sound will be back to normal volume.
I hope you could help me on this issue.
Info:
Windows 11 Pro 24H2
No other available updates on Windows Update
Are you hearing the sound fluctuation when selecting any particular audio output device or is it across all devices?
Can you try changing the FxSound preset, adjust the equalizer and audio effects and see if the fluctuation goes away?
Can you please share the system information of the PC where you have installed FxSound, like OS version and hardware configuration.
Have you installed any other audio enhancement applications? If multiple applications try to process the audio stream it might impact the audio.
Hi @Manochvarma,
Such audio can also be caused If exclusive mode is enabled on the playback device and any exclusive mode application tries to the use the playback device.
So, please check exclusive mode setting also for the devices.
If the problem is still not solved, can you share a recording of the issue and file the issue in GitHub, Issues · fxsound2/fxsound-app
