Hi, feedback a character garbled problem.
The characters in the lower right corner are garbled, and you may need to adjust the character encoding.
Other displays are normal.
Thanks dayanzai for reporting this bug. I have fixed it and uploaded the new beta version 1.1.14.4.
Thanks for the fix.
But I found that when using the Ctrl+Alt+Q shortcut, the tray prompt is still garbled.
Ctrl+Alt+A It has been displayed normally.
You may need to check the shortcut related settings more, thank you for your work.
Thanks for pointing this out. I find this issue where ever formatted strings are used. I am looking into the fix. Will post the next version with the fix soon.
The garbled text issue is fixed. The fix is available in the updated beta release 1.1.14.5. Please download and use this version.
Thanks for your work, it’s working now.
I will share it to more Chinese users.
Thanks for your support and encouragement!
