Serious problem FxSound (free)
I want to manually put the hz, I can’t put it in 400hz, it stays in 399hz or it passes by.
Fx Sound Enhancer is better for audio than the free program. (blue program)
The sound is less clean and clear.
many options are missing.
an option to disable one or more features to change the audio.
I want the same settings as blue Fx Sound Enhancer.
Thanks for reading.
A Man and his son were once going with their Donkey to the market. As they were walking along by its side, a countryman passed them, and said: “You fools, what is a Donkey for but to ride upon?”
So the Man put the Boy on the Donkey and they went on their way. But soon they passed a group of men, one of whom said: “See that lazy youngster, he lets his father walk while he rides!”
So the Man ordered his Boy to get off, and got on himself. But they hadn’t gone far when they passed two women, one of whom said to the other: “Shame on that lazy lout, to let his poor little son trudge along!”
Well, the Man didn’t know what to do, but at last he took his Boy up before him on the Donkey. By this time they had come to the town, and the passers-by began to jeer and point at them. The Man stopped and asked what they were scoffing at. The men said: “Aren’t you ashamed of yourself, for overloading that poor donkey of yours and your hulking son?”
The Man and the Boy got off, and tried to think what to do. They thought and they thought, till at last they cut down a pole, tied the donkey’s feet to it, and raised the pole and the donkey to their shoulders. They went along amid the laughter of all who met them, till they came to the Market Bridge, when the Donkey, getting one of his feet loose, kicked out, and caused the Boy to drop his end of the pole. In the struggle, the Donkey fell over the bridge, and his fore-feet being tied together, he drowned.
“That will teach you,” said an old man who had followed them: “Please all, and you will please none.”
  • Aesop’s Fable “The Man, The Boy, and The Donkey”
How serious you are.
If you are used to how DFX classic sounds I exported the default preset and it sounds pretty much the same as the old one :slight_smile:
Save it as .fac file and see if it helps. Inaccurate sliders are very common in software.
This is not from blue FX sound enhancer but you could try doing the same as I did, export your preset and try importing it in the current one.
CLASS1 : Effect Type
9: Version
DFX Classic
0: Double Params Flag
1: Total number of elements
51: Main 0
26: Main 1
0: Main 2
51: Main 3
51: Main 4
68: Main 5
0: Element Number
   0: Param 0
   0: Param 1
   0: Param 2
   0: Param 3
   0: Param 4
   0: Param 5
   0: Param 6
7: Number of Application Dependent Integers
0: Number of Application Dependent Reals
0: Number of Application Dependent Strings
1: Integer[0]
1: Integer[1]
1: Integer[2]
1: Integer[3]
1: Integer[4]
0: Integer[5]
2: Integer[6]
10: Number of EQ Bands
1: On/Off Flag
Band 1
   62.5: CF
   5.35433: Boost/Cut
Band 2
   110: CF
   0: Boost/Cut
Band 3
   200: CF
   0: Boost/Cut
Band 4
   295: CF
   0: Boost/Cut
Band 5
   650: CF
   0: Boost/Cut
Band 6
   1200: CF
   0: Boost/Cut
Band 7
   2120: CF
   0: Boost/Cut
Band 8
   4550: CF
   0: Boost/Cut
Band 9
   6300: CF
   0: Boost/Cut
Band 10
   16000: CF
   0: Boost/Cut
Hello @Moon,
Most users come here to get an issue troubleshooted.
Your program seems to be working just fine…
Movimiento es vida; Panta rei; everything changes…
