Hello. I have a problem with the program. If I connect Bluetooth headphones, the sound from FxSound becomes louder. But if you connect headphones or speakers by wire, the sound becomes quieter on the contrary. If I close the program, the sound becomes loud again. This started a few months ago, after which I uninstalled the program. Now I installed it again, but the problem has not disappeared.
I tried reinstalling FxSound, running the program as administrator, installing new Realtek drivers, deleting headphones in Device Manager, setting all volume sliders to maximum, disabling sound enhancements, changing headphone frequency, checking and resetting mixer settings, updating bios, but nothing helped.
I also noticed that if I switch to another device in FxSound and then back to wired headphones, the sound gets loud for a second and then quiet again.
I tried both the latest stable version of the program (1.1.22.0) and the latest beta version (1.1.24.0).
Hi Andrey,
For similar issues on volume dropping, we had given a suggestion to check the volume set in volume mixer and in some cases it worked because the volume was set to low in the system settings or for a specific application in the volume mixer. Can you go to the advance options in System → Sound and check if the volume is set correctly for the device and volume mixer for system sound and the apps.
Checked and set the volume to max everywhere, but nothing changed. I also decided to check the output volume with Audacity. The volume on the FxSound speakers is fine, but when it sends the sound to the headphones, it’s as if something is limiting the volume. Although the volume is set to 100% everywhere. https://drive.google.com/drive/folders/1UACGoO2a3bNZojWkfV73ZtdikoFe5kwg?usp=sharing
Thank you Andrey for providing all the details on your audio settings. These settings look good for me.
Since the volume issue is specific to wired audio output on Realtek, can you confirm if you have installed any Realtek audio enhancement applications? We have seen such issues in the past where multiple audio enhancement applications being installed on the PC which can impact the audio output.
Also please check the volume set through Control Panel ->Sound → Adjust system volume
Thank you for waiting. I checked the mixer in the control panel. Everything is set to maximum there too. I didn’t find any other programs to improve sound in the system. About Realtek. I installed Realtek internet and audio drivers, Dragon internet management program and Realtek Audio Console program. Also in the system there is Realtek Audio Universal Service in autorun and in services.
I tried the following: uninstalled Realtek Audio Console, uninstalled Realtek Audio Driver, disabled Realtek Audio Universal Service in autostart and in services, restarted the computer. But it didn’t help.
Now I decided to try to install the old program FxSound Enhancer 13.028. It works just perfectly. The sound with it becomes only louder. Then I decided to install the latest version of FxSound 1.1.22.0 again, but the sound is still very quiet. If there are older versions, I can try them all. Maybe on some of them it will be fine, and on the next one it won’t, and then it will be clearer where the problem is.
Sure; there’s a link to VideoHelp under point zero of the main troubleshooting list at the top, where you can find all the previous versions of the purple FxSound.
I installed the oldest version I could find (1.1.14.0) and the problem still remains. My assumption is that maybe the problem is in the driver (since FxSound Enhancer and FxSound 1.1.14.0 have different drivers), or after uninstalling there are still settings somewhere (but where?).
I wanted to test the driver idea. I tried to install old drivers from FxSound Enhancer on FxSound Speaker, but FxSound stopped starting.
The drivers for Windows 7 and Windows 10 are present in %PROGRAMFILES%\FxSound LLC\FxSound\Drivers
To install or uninstall the drivers use the fxdevcon utility of the corresponding CPU architecture. For example, to install Windows 10 64 bit drivers go to,
I have this exact issue and have tried everything suggested here with no fix. Hope this can be fixed soon as before I really enjoyed FxSound but as of now it is completely unusable due to how quiet everything becomes.
Hi @dec.
Welcome to the FxSound forum.
Sorry for the inconvenience.
I assume you’re currently running v1.1.22.0.
Which version were you running before the problem started?
Just to verify: does the problem occur with only one audio device, or with all devices?
And have you read through the main troubleshooting thread linked at the top of the forum yet?
If the problem cannot be solved, you can find a summary of alternatives there, at the end.
Hello. I’ve already solved the problem, but I haven’t written a solution. I’m sorry for that. In general, I’ve found two solutions to this problem:
1. The way to completely fix the problem with Realtek devices is to reinstall Windows.
2. Alternatively, you can install the standard Microsoft driver for headphones/speakers instead of Realtek. This will restore the sound to normal. However, this will prevent the Realtek Audio Console from managing the devices (but if you haven’t used its functionality, you won’t lose anything).
It’s possible that someone will find a way to fix this issue on Realtek devices without reinstalling Windows. If so, it would be great.
