Hi everyone,
I’m having some trouble with my setup and could use some guidance. Everything is working fine, but I’m a bit confused about the potential settings in Windows 10 and foobar2000. I’ve got a few questions, but first the screenshot:
Device Manager: These four devices are currently active when I check Device Manager (screenshot below). Should I uninstall, disable, or tweak any of them?
Windows Sound Settings: Here’s a screenshot of what shows up under Windows Settings > System > Sound > Manage Sound Devices. Which devices should be enabled or disabled?
Foobar2000 Settings: This is where I’m most confused. Switching between different devices in foobar2000 changes the audio quality noticeably. I mainly use foobar2000 for playing music, so I want it to sound right.
- When I select “Primary Sound Driver” in foobar2000, the audio plays fine.
- However, when I switch to my actual headphones (Headphones [2- Arctic 7 Game]), the volume and gain seem to increase drastically, and the sound becomes overly compressed, like low-quality mp3s from the early 2000s.
- If I choose “FxSound Speakers (FxSound Audio Enhancer)” in foobar2000, the sound is similar to “Primary Sound Driver,” but with a slightly lower volume.
So, which device should I select in foobar2000 for the best sound quality?
Thanks in advance.
