Notification Update Speed
When using the hotkeys to change presets, or toggle the program on/off the notifications don’t update quick enough to be useful. You have to wait for the notification to disappear before using the hotkey again otherwise they’ll just queue up behind it
Would really like for the notifications to overwrite the previous notifications it’s displayed or just disappear quicker
I have this problem too. We used to use our own notification system that didn’t rely upon using the Windows notifications. @bvijay is there a reason we switched and do you think we should switch back?
Since there were requests for option to enable/disable the notifications, I switched to Windows notifications. Since Windows notifications for the application can be disabled through OS Settings.
We can consider switching back to our custom notifications and provide an option in FxSound settings to enable/disable notifcations.
Ah I see. Yeah let’s switch back and add an option to enable/disable notifications in a future version.
