When I use USB mode on my headset FxSound works great, but when I go with the wireless mode the FxSound turns down the volume, even If I use the 100% of the volume I still hear it low, I don’t know why does this happens, I got my drivers up to date, I’ve tried everything but nothing works with the wireless mode.
Hi Pizzero,
Would recommend giving this thread a scan first; let me know if this improves the situation or not:
@Pizzero Is the headset audio format the same in both USB and wireless modes? If not, can you change the default format of the headset in wireless mode and try.
Yeah is the same, the problem is that when I open FXSound effect my volume goes down instantly, and it sounds like If I were under the water, I got the Corsair HS80, and when I change from wireless to USB Mode or USB to wireless everything goes bad, I play PUBG and when I installed this program I could hear everything, footsteps around me, detect where the shots come from, but now, no matter what mode I use It sounds really bad, I tried everything already and nothing works
A user with the same headset reported the same problem a while ago,
