I’m only getting around 5-10% volume even though the settings are maxed out on both my device and the headphones themselves. I’ve already looked through the forum for solutions and tried everything suggested, but unfortunately none of them worked.
Interestingly, the headphones work perfectly fine when I use them:
- With FxSound but using with a cable, instead of Bluetooth
- Without FxSound, with bluetooth
Any advice on how to fix this low volume issue with would be greatly appreciated!
Attached 3 screenshots. Let me know if anything else is required. Thansks
