Hi @Foioyoi,
Regret to inform you that there’s no volume control built into FxSound’s main interface, so you’ll have to adjust it some other way.
Under standard circumstances, each device in your Windows Sound Settings has its own volume control, and your chosen media player probably has multiple options for volume control as well.
Many media players allow you to lower the baseline volume by fiddling with their additional settings (this can be done effortlessly through VLC’s Equalizer option, for example).
Another option would be to install a small additional piece of software like EqualizerApo that has a PreAmp, which allows you to lower the baseline volume very easily as well.
Hi!
I hope I didn’t misunderstand your problem…
You can control all working channels - including the main Windows volume - with this, completely independently, I use this for this purpose: EarTrumpet
You may be describing a different problem:
Windows does not remember System Volume setting
or
Software is configured to reset System Volume
Windows/DFX/media player of choice “should” remember the current volume setting. Examine your configuration carefully. Failing that, there is a Windows setting…
