FX should show an alert every time a video edition program is opened since it modifies the final audio of the recording, and the other people that the video does not have FX, therefore they listen differently.
I am learning to edit videos and find this peculiar inconvenience.
Thank you very much for the program, it is the best thing that exists to equalize, it is a before and after. ![]()
Hello Claudio,
Thanks for the suggestion. Glad to hear you’re enjoying the software.
Whether or not the audio gets processed by FxSound, likely depends on which devices you set as your inputs and outputs in the video editor, in FxSound’s drop-down device selection menu, and in Windows Sound Settings.
Could you please specify which video editor you use, and also, if the FxSound audio boost is only applied while working in the editor, or also in the videos produced with the editor?
Because if you are able to record videos with boosted audio, this would also be helpful info for @VegasDave, who posted this thread ten days ago,
