Need a way to boost and enhance audio when transferring video footage to PC
I am transferring home movies on VHS-C videotapes to my (Windows) PC, and then burning DVDs from there. I’m having a problem in that the resulting audio is very flat, has no dynamic range, and ambient sounds are non-existent. Pretty much the only audible sounds, after the transfer to the PC, are of people talking near the camcorder. Could FxSound be used in the transfer of footage to my PC? And, would it help solve this problem?
Without your space helmet, Dave, you’re going to find that rather difficult…
I only know one way to re-record something while applying FxSound processing, namely with VoiceMeeter, and this has only worked with audio so far.
It’s highly likely that there are similar mixing tools available, but I have not heard of those yet.
