hello.
how do i record what at heard when i use fxsound. The fx is working on my headset but i want also to record what i heard in my headset and then play it without the fxsound to see if the sound is the same as i have used the fxsound. Thank you
hello.
You can record audio with FxSound processing applied using VoiceMeeter.
Getting it set up properly, however, is rather difficult.
See:
