FXSound has pop up “Exit cofirm” window when closing. It asks to NOT SHOW that window on next closing. After checking the box it still shows up. There have been at least TWO updates since I was told that this problem was a)known; and b) would be addressed.
Any idea why it is still an issue?
Could you provide a link to those comments?
This appears to be your first post on the forum, and I don’t remember anything being said on that topic.
I have some hypotheses - because the problem is minor and not a top priority, because @bvijay has a lot of work and has not found the time to address it yet - but since I’m not involved in any programming, ultimately, you’ll have to ask him yourself.
It was an email from “help Desk.” Dumped it figuring it was a moot point.
Still, it is a non-functioning feature and should be addressed - fix it or drop it.
Been programming for years (especially other folks’ code) and am pretty sure the original coder would need about 2 minutes… just sayin’
Noted and forwarded.
Hi @gfhasman
Are you referring to this pop-up?
If there is any change in the equalizer settings or audio effects, FxSound prompts to save the changes to a preset before exit.
Apart from this there is no other exit confirmation pop-up in FxSound.
I also don’t really have a clue what pop-up you’re referring to.
The only “exit” that comes to mind is the tray icon option, but no confirmation is asked for that.
