By factory presets I mean the presets that come loaded in FxSound by us. I could see some of you guys not using some or any of these presets and it could be helpful when swapping between the preset options if you didn’t have presets you weren’t using.
          In my opinion this is not a good idea, I often use them. Better option would be to add new presets to existing ones.
          More options for the user will always be accepted. You don’t have to delete them, instead, give the user the option to disable them. I personally deleted the factory presets since they didn’t fit my specific use. I created three presets for now. Much easier to cycle my profiles than cycling through everything all the time.
