I just downloaded fxsound because I got new speakers for my computer and wanted it to sound good but everytime I launch it the program crashes immediately. What do I do
What version of Windows?
Do you have *.dmp files (for example - FxSound.exe.11692.dmp) in %LOCALAPPDATA%\CrashDumps folder?
Good evening Eddy,
It would be helpful if you could share which version of Windows you are running, and which version of FxSound you installed.
Also, there’s a list bannered to the top of the forum with basic troubleshooting suggestions and instructions for proper setup.
Please run through the list first, and post back to let me/us know your results.
windows 11. I cant find the appdata folder tho where could I find that
windows 11. I downloaded off microsoft store. Ill give that a look thanks
its could be due to a list of issues i think its your cpu check and see if u have at least 4 cores
I have ryzen 7 3700x
