Beta announcement - FxSound language options
The beta version 1.1.14.1 is available for download at
https://s3.amazonaws.com/downloads3.fxsound.com/fxsound/2/Beta+Testing/fxsound_setup.exe
This version supports the languages - 한국인, Tiếng Việt, bahasa Indonesia, Português, 简体中文 and 繁體中文
Please try this version in your language and send us the your feedbacks
To override the OS language and load FxSound in a different language please use this command line option,
FxSound.exe --language=language code
The command line options available are,
Korean
–language=ko
Indonesian
–language=id
Vietnamese
–language=vi
Portuguese
–language=pt
Chinese (Simplified)
–language=zh
Chinese (Traditional)
–language=zh-TW
–language=zh-HK
–language=zh-MO
–language=zh-Hant
For example,
FxSound.exe --language=ko will open FxSound in Korean even if the OS UI is in English
Not a great start i would say…
The language options parameter is not for the installer. After installation set the parameters to the shortcut properties. The Target value in the shortcut properties can be “C:\Program Files\FxSound LLC\FxSound\FxSound.exe” --language=vi
I think it’s an error about the font. Some of the character are disappearing
I have uploaded a new version 1.1.14.2 with a new font for Vietnamese.
Can you please try this new version?
The new font seems ok but the reset button looks a little bit cramped. Possible fix: automatic change the width of the button OR shorten the sentence (imo it’s a little too long)
Thanks for your inputs. We will make the formatting changes.
If there are any corrections required in the translation, please let us know.
Updated beta version 1.1.14.3 is available for download.
Changes in this version,
  1. Translated text from members are included
  2. Spanish language support is added
  3. Language can be switched from Settings dialog
Updated beta version 1.1.14.4
  • Bug fix in Chinese version where garbled text was displayed in system tray notification
  • Spanish text updated
Updated beta version 1.1.14.5
  • Bug fix: Garbled text was displayed in the system tray notification in few scenarios where strings were formatted
Uploaded beta version 1.1.15.5
Bug fix: Playback device connection handling issues across system standby/resume states
The issues around retaining the selected audio output device across system power states changes are fixed in this beta release.
If the option “Automatically switch to newly connected output device” is checked
  • If the selected output device is disconnected, then output will automatically switch to another output device
  • If the system goes to standby and the selected output device is not available on resume then the output will switch to the available device
  • If the system goes to standby and the selected output device is available on resume then the output will remain on the selected device
If the option “Automatically switch to newly connected output device” is unchecked
  • If the selected output device is disconnected, then output will be off
    • if the disconnected device is connected then audio will resume
    • if the disconnected device is not connected, then manually select a new output device from the UI or through keyboard shortcut
  • If the system goes to standby and the selected output device is not available on resume then the output will be off
    • if the disconnected device is connected back then audio will resume
There are some changes in our download server. The beta version is now available at https://download.fxsound.com/beta.
Thanks Vijay! Great work :slight_smile:
