same for me after updated windows 11 25h2 to new pack update (kb5101684)
problem is, even the normal sound system is not working
well u should try driver booster or something (driver software updates etc ) to check your windows sounds drivers for me i have the same issue like you but my system sounds works well
@Ishu Please check the FxSound Audio Enhancer device status in device manager
