Hello all,
First of all I must say that FXSound is trully awesome, and I love the options it provides me with!
However, when trying to switch the audio to my wireless Logitech Pro X headset, once I click to change, I get continous audio feedback and I am not able to use it.
FXSound runs on a clean W11 installation, let me know if any other info are needed!
Good evening Stelios, welcome to the forum.
First thing I’d recommend is downloading v1.1.22.0 and running the installer, since your screenshot is from a previous version.
You can download it for free on fxsound.com as always.
In addition, there’s also a main troubleshooting list located at the top of the forum.
Damn that was embarassing!
Thanks a lot @doolhoofd! That was a good reminder of Occam’s razor principle.
No worries, all good.
Did you get your headset to work?
That was the objective, after all.
Yes the headset now works perfectly. It seems the update fixed the issue.
Nice!
Thanks for the good vibes.
