1.2.9 Switching Equalizer modes - the graph is not reflected correctly
After switching the number of lanes from 5 to for example 10 - equalizer bands are shown at 0dB. Then press the sound to pause and continue play, then the graph changes to the original one.
1 2 10
not fixed
Which preset did you test with?
I tested with a few presets which have significant variance across bands like Voice and Transcription. From settings changed the bands from 10 to 5, the gain selection in the equalizer immediately reflected the change.
in 10-band mode - change the EQ curve.
switch to mode - 5 and everything resets. Switch back to 10 - other frequencies changed that I didn’t change.
I am able to reproduce this behaviour. Will get it fixed.
