Along this same issue, which I already noted in a reply to a much older band issue post, which seems to have been removed due to some body arguing with me that this is not happening, well to cut to the point, there are certainly some implementation issues spanning the setting of band selection, when you launch pc whatever setting you left it on, the overall sound will definitely be quieter than when after you change it from any band to any other band from that point until computer restart the overall sound will be a little but definitely noticeably louder, also changing bands has other weird quirks like bands 5, 10 and 31 sound much more natural while bands 15 and 20 sound very computerized, and to this end, if changing from a computerized band to a more natural sounding one, it will still retain this computerized deformation, also each band has a unique deformation each slightly different from the other, I am willing to accept that extra ordinary noise is the result of my speakers failing and this being a low end device and not that this started happening with a certain FXSound update, but the rest of the effects I hear and described above are almost surely not the intended behaviour of the band settings.
There was a bug in changing the frequency gain values proportionate to the changing the number of bands. The is fixed. Please wait for the next release for the fix.
