As soon as i updated my FxSound to v1.2.13.0 it changed my max Hz limits on every band
I use the 10 Band equalizer and now that my Hz frequenzies are different it sounds so bad on my headset and i cant do anything about it
How do i fix it?
Can i fix it?
If you want to change the audio frequency in FxSound, keep in mind that the EQ sliders adjust specific frequency ranges, but they don’t change the actual sample rate of the audio. If you’re trying to switch between 44.1 kHz and 48 kHz, check your Windows sound device properties under Advanced settings. The available options depend on your audio device and driver.
