Presets frequency range and bands
In the current beta build the frequency changes still do not stick or get saved if one changes presets after changing bands, only the currently active preset appears to have the frequencies set properly but only on the surface as they are not saved values, so if one switches a preset after changing bands and then back it will again be a broken drifty mess of values, and all other presets not active during band change do not properly convert all their values to the changed band, also there appears to be a drift of 1-2 hz on the first or first two ranges after changing bands, and lastly there appears to be a glitch when using the kb arrows to change frequency values, unlike when using a mouse they will not change for a few key presses near certain values, you need a few arrow presses for a single visible change, some times it snaps to a few values instead of going one by one, one way or another it is some sort of a quirk of the dials and using a mouse vs kb , please have a look at this, and please make the frequency stick to whatever is set, regardless of band changes, currently, if one switches between 5 and 10 band options, frequency band settings always drift around instead of staying centred or converting to an equivalent value of the same range.
Thanks for reporting these band frequency issues.
We will prioritize and address each of these issues.
The problem with frequency values not changing between presets is still present. Don’t get me wrong, I’m grateful for the software, but I think this is a major issue that needs to be resolved. Otherwise, what’s the point?
In 10 band equalizer the frequencies were changed according to ISO range and the preset frequencies were not in ISO range. I have fixed this discrepency and the equalizer band frequencies are similar to the preset band frequency ranges. This change is done in v1.2.14.0.
If the number of bands are changed, then the gain values are interpolated, because some values may be unknown. So, the equalizer graoh may not be the same as the original preset. We are working on the fix for this.
Thank you for the reply. It’s great to have this working again. Cheers!
