Frequency settings
Firstly, apologies if this question has been asked before.
When I make a new Preset, strange things happen with the dial-wheels along the bottom.
On a 10-band equalizer, for example, the ‘Default’ fifth wheel has a range of 350-770Hz. Once I lower it, the top range becomes 650Hz and will go no higher. The lower end always remains the same. All wheels behave similarly. Is this what’s supposed to happen or am I missing something ??
Great product by the way, I’ve been using it for years.
Thanks @Rigsby for pointing this out. This could be a bug which got introduced when we implemented variable number of bands from 5 to 31 from fixed 10 band equalizer.
Will get it fixed to keep the frequency range unchanged in the 10 band equalizer.
