Update failing with installer not responding
When I get notified of an update, I proceed with the process but I get this box displayed that the INSTALLER IS NO LONGER RESPONDING.
Can you try uninstalling the previous version and then download and install the latest version instead of updating?
I can’t even uninstall it without the same message about the installer. Tried uninstalling using Windows Control Panel/Programs. WEIRD!
JC
Someone replied to your post.
| bvijay Lead Audio Engineer
February 24 |
Cannot install a new FX app - Get Help - FxSound
When updatting FxSound, it corrupted itself… Now i can’t open it, uninstall it, nor reinstall it to even attempt to fix the issue… please help! [The file ‘Dfx Install.dll’ is not marked for installation] - Get Help - FxSound
Cannot completely uninstall FxSound - Get Help - FxSound
@jcarra0826
I have attached some links to previous articles which discuss uninstallation. Please go through them and see if they seem relevant to uninstall the app. I will let you know if I find some solution in the meantime.
