Suggestion for upgrade - startup option (general settings)
Greetings: I know that you’re just doing limited updates, but I have a suggestion to enhance your product (which has been very helpful for me)…
If there could be an option on the General Settings page for “Launch FxSound on startup” that would be great (right now I’ve manually set it up, but others may find this helpful). Thanks for the great product! JEP
Thanks, John; that’s a reasonable and helpful suggestion, and I’ll be sure to pass it on to the team.
In the meanwhile, I do remember James saying the following:
