please add Minimized start (system tray), starting options
thank you
The version 2.0.4 restarts exactly as you close it.
So if it was minimized in the system tray, then it reopens minimized.
Moreover it remember also the window positions and wich panel was opened.
Soon the version 2.0.4 will be unified with the main FxSound version, in the meantime you can download it from here.
After the download unzip the files and start the “FxSound_Enhanced_Installer.exe”
( or read the file README to learn all about this installer )
yes thank you!
