Stuck behind an on top
Mini mode was on top and from there I imported some presets from an empty folder.
I could not move the on top window because the file dialog kept focus. There was no f’it button visible (only ‘Import’). I was stuck. I could neither complete the import or close the dialog. I could not use the common window controls because they were behind the on top.
Only now do I realize I could have changed screen resolution to access the control.
Thanks @Antman for reporting this issue. Is this on the latest version 1.1.34.0 where the mini mode gets docked with the system tray?
Version 1.1.33.0
I use the autohide taskbar feature of Win11. That has no direct bearing on > the mini-mode docks too tightly to the corner and covers the systray. I have controls that cannot be accessed while mini-mode is docked. Also, it does not remember its last position. I am “pro-docking” but it should not cover the systray (or scrollbar in a perfect world).
Why does mini-mode have to be so big? Can it be transparent?
The context menu is looking really clean. The font for “Playback Device Select” seems oversized but the presentation functions well. My eye is immediately drawn to the list.
This comment/question seems to fit well here. The notification area is momentarily stuck behind a notification pop-up on top of it.
Is it possible to offset the systray notification pop-up upward? Currently, it covers the systray. When I use the FXSound systray icon, I almost always also use a second systray icon. I must wait for the pop-up to fade away.
I use the taskbar auto-hide feature in Windows.
