That’s great!
Please rename the attached source file to .cpp and run it with Visual Studio. AudioEnum.txt (4.3 KB)
You should get an output similar to this, where channel, sample rate and bps are printed for active devicea
1.Speakers (SB ROAR SR20A) {02d6ffd0-dc5e-4e56-9604-311741c7f7e2} [Unplugged]
2.Speakers (FxSound Audio Enhancer) {2654ece6-1bcf-42b6-b0bb-14054036c8c6} [Active]
Number of channels:2
Sample rate:48000
Bits per sample:32
@oss96 the only difference I see is the sampling rate between DT770 Pro and DT990 Pro. Though both sampling rates are within the range supported by FxSound sound, if the issue is seen on a particular sampling rate it will help us debug the issue.
@bvijay thank you.
It seems like the sample rate isn’t the problem.
Do you have any other leads, what it might be? Can I provide you with any other information?
Thanks @oss96
When you said all devices exhibiting this behaviour, are you referring to the Nvidia and Realtek output devices on your PC. Do you get mono audio output through HDMI and headphone connected to AUX?
I will also check for scenarios in the code where the output can fallback to mono.
